Showing results for tags 'degree symbol'.
I have a list routine that adds the bearing and distance on a specific layer to a line, however, I want the bearing to display with the degrees symbol not the letter d. I'm not sure if I can use the (vl-string-subst "%%d" "d" feature with a get selection or where to put this in my routine?) The lisp routine is below defun c:lbl(/ oldlay part theight scaleget la_text laname) ; ADDS LENGTH AND BEARING TO LINE (command "ucs""w") (setq Surv-text_layer_name "SurvTXT") (setq Surv-text_layer_colour 7) (setup_layers) (SETQ PORTVAL (GETVAR "CVPORT")) (setq part (getvar "dimscale")) (setq theight (* part 3)) (setq oldlay (getvar "clayer")) (command ".LAYER" "m" Surv-text_layer_name "C" Surv-text_layer_colour "" "") ; IF PAPERSPACE DONT MULTIPLY TEXT HEIGHT BY DIMSCALE (IF (= PORTVAL 1) (command ".DTEXT" "S" "STANDARD" pause 3 PAUSE) ) (IF (> PORTVAL 1) (PROGN (setq scaleget (getvar "dimscale")) (if (< scaleget 2.0)s (progn (setq scaleget (* scaleget 1000)) );end progn );endif (setq la_text (itoa (fix scaleget))) (setq laname (strcat Surv-text_layer_name "_1-" la_text)) (command "layer" "m" laname "c" Surv-text_layer_colour "" "") );END PROGN ) (prompt "\nSelect lines to label: ") (setq ls (ssget) len (sslength ls) ctr 0) (while (< ctr len) (setq lin (ssname ls ctr) p1 (cdr (assoc 10 (entget lin))) p2 (cdr (assoc 11 (entget lin))) p3 (polar p1 (angle p1 p2) (/ (distance p1 p2) 2)) p4 (polar p3 (+ (angle p1 p2) (/ pi 2)) (/ 0.01 (getvar "CANNOSCALEVALUE"))) p5 (polar p3 (- (angle p1 p2) (/ pi 2)) (/ 0.01 (getvar "CANNOSCALEVALUE"))) ) (setq dir (angtos (angle p1 p2) 1 4) dis (rtos (distance p1 p2) 2 3) tang (angtos (angle p1 p2) 2 4) ) (command "text" "j" "bc" p4 theight tang dir) (command "text" "j" "tc" p5 theight tang dis) (command ".rotate" pause pause pause p3 "180") (setq ctr (1+ ctr)) (command "ucs""v") (command ".layer" "s" oldlay "") );end while (princ) );end function
- 2 replies
- degree symbol
- change d to %%d in text selection
- (and 1 more)
