Showing results for tags 'data extraction'.
I came across the attached LISP routine that allows attribute information to be extracted into an excel document. Unfortunately this code searches the entire drawing for attributes, when I need only specific blocks to be selected. I am looking to modify the following code, so that it will prompt me...
- 17 replies
- data extraction
- attribute
Hello, I have been trying for the last few days to automate out a process but have found myself pretty stuck. The process now involves manually going in and looking at the properties of the polyline and copying over the length to a separate excel file and matching it to the block that it...
- lisp
- hyperlink text
(and 4 more)
Hello All, I am working on making Bills of Materials with Block information. I use tubing as a main component in my data extractions. What I would like to do is be able to extract the text overwritten length that I dictate from the all dimension leaders with the same part number, and add them to...
- 3 replies
- dimension
- data extraction
Hello, I have an AutoCAD Drawing with different Blocks. These blocks have some of the attributes names in common (Height, Length & Width). Can I extract the attribute data from selected area in drawing to an existing excel sheet with standard template such that the block name comes u...
- 5 replies
- dynamic blocks
- data extraction
Extract line attributes including both handle and global width field
newtocad posted a topic in AutoLISP, Visual LISP & DCL
Hi all, I have done data extraction of my CAD file to excel using AutoCad 2017 (full version), which includes global width, but did not include the handle or any other type of ID to distinguish the lines from one another. Is there any way to get the attributes of lines, specifically global width...- 5 replies
- global width
- data extraction
Hello all, I'm looking for some way to convert ESRI ArcGIS geodatabases and/or shapefiles into CAD linework using vanilla AutoCAD. In my office (petroleum industry), we use utility data, parcel and ROW data, and topo data (especially contour lines) the most, so these categories are the stuff w...
- 8 replies
- gis
- data extraction
Back into the world of AutoCAD after a 20 year absence. When exporting dynamic block parameter data to Excel using the wizard, all data ends up as text (ex: 3'6 1/2") which is useless for using within Excel formulas. Is there a way around this other than changing the units to decimal before I extra...
- 2 replies
- dynamic blocks
- data extraction
Data Extraction to Excel turns data into dates.
arkitectin posted a topic in AutoCAD Drawing Management & Output
Hello Everyone, I'm using AutoCad 2014 and have Microsoft office 2007. I use attributes in every drawing. Most have identifications as 1-01 which stands for Floor 1-Item #01 or 3-27 which stands for Floor 3-Item#27. When I use the data extraction, I extract it to the drawing, everything is correct...- 2 replies
- data extraction
- attribute blocks
I'm trying to automate our work flow. I need to be able to place incrimental numbers for which I've found Lee Mac's numbering suite.http://www.lee-mac.com/numinc.htmlhttp:// I am placing numbered lamps for a lighting control network.Every lamp in the network has a unique number (from the numberi...
- 2 replies
- network nodes
- data extraction
Hi guys, I've created a table through data extraction using blocks for data. The table isn't showing the text for comments, keywords,title or subject that is in the drawing file for the different blocks. Any ideas why this is so? Thanks
Dynamic block value not showing in table
da3d4lu5 posted a topic in AutoCAD Drawing Management & Output
Hi guys, I've created this dynamic block for work. Its an overhead cupboard with 4 doors. My problem is that when i create a table through data extraction the value for the length and height for the doors aren't shown (The column this there with a heading, no value), the length of the ca...- 6 replies
- dynamic block
- data extraction
Good Day looking for assistance with extracting data from an AutoCAD table. Hav found a fex examples on how to create a table in AutoCAD with VB.Net but no luck on how to loop through the rows and columns in an AutoCAD table and see the items within. Want to be able to loop through a list of dr...
- 5 replies
- data extraction
- autocad
Getting Coordinates of a polyline with a constant X step
Steven29410 posted a topic in AutoCAD General
Hello everyone, in order to obtain a seabed profile for a school project, I need to get the Y coordinate of a polyline on several Kilometers with a fxed X step of 2m between each point. For the moment, the only manual solution I have found is to create a vertical line every 2m and to get th... -
Add Entity handle to the generated data extraction table
danie7LT posted a topic in AutoLISP, Visual LISP & DCL
Hi everyone, I'm following this great forum for a year now and it has help me A LOT! so first of all thank you all. Now for our Bill of Material we generate tables with the data extraction function which is great since it's updating itself on every change in the selected entities. The BOM can...- 1 reply
- lisp
- data extraction
Attributed block count/ extraction
onlyonealice posted a topic in AutoCAD Drawing Management & Output
I would like to extract a furniture schedule by using attributed blocks. I would like attributes like Item #, Color, Size, Location, Description, Manufacturer, etc…. The problem with the data extraction system that I am having is that in order for a chair with a tag to be considered the same chair a... -
AutoCAD Lisp Help: Attribute Extraction into Excel BOM
ml3428 posted a topic in AutoLISP, Visual LISP & DCL
I was able to find this Lisp Routine "ATTOUT" forexctracting attributes into an Excel document. I currently have blocks createdthat contain 4 different attribute values. These attributes are exctracted in creating B.O.M's to automate Mfg. processes in conveyor equipment construction.In devloping the...- 10 replies
- data extraction
- attributes table
Which Table Formula will work to achieve this result?
colors posted a topic in AutoCAD 2D Drafting, Object Properties & Interface
Hello, I have about 50 blocks and each contain manuf. nos. The Data Extraction program is utilized which links these blocks to an excel spreadsheet to extract desc. & unit. to extract this data and placed in a bill of material together with the correct quantity calculated by this template.... -
Apologies if this has been posted already - been searching everywhere for an answer to this one! Here is the problem with the process put simply: Start with a new drawing Drawn a rectangle. Place a block which has an attribute with a number at each corner. ie. 1-4. Convert all o...
- 4 replies
- nesting
- data extraction
Updating between excel sheet and autocad dwg.
Jach posted a topic in AutoCAD Drawing Management & Output
Hello everybody My firstpost in here and I am existed, woooot… ahem. Here is mylittle problem, I have been trying to find a solution to this In a long time. I amtrying, to make a data extraction with Link External data with linking to aexcel sheet. Everything worksfine, with the data extraction.... -
Hi all, I am trying to extract data from a block for eg. area of a polyline (that had been made as a block) so that I can export it as an excel schedule. I have been unsuccessful so far. Whenever the data extraction window asked for what kind of information to be extracted, area is not one of th...
- 1 reply
- blocks data extraction
- blocks
- (and 3 more)
Linking Room Names to multiple drawing files using fields
Movieangel posted a topic in CAD Management
I have figured out how to link my room names that are on multiple layers (ceiling, 1/8" scale, 1/4" scale, signage, etc.), but I am wondering does anyone know if I can link them outside the current drawing. I would like for when I update my room name and number for them to automatically update in Me... -
Good Day looking for code in vb.net where i can retrieve what exrefs are in a drawing file without opening it. Will also like to be able to edit the exrefs paths and files within the drawing database. The method would also be useful to extract attributes etc. from drawing files without open...
- 4 replies
- vb.net
- drawing editing
I've found a number of articles outlining the process of extracting data from AutoCAD to an Excel file, but I'm wondering if it's possible to do the reverse. For my work I have a number of databased already established in Excel and am able to create information tables rather quickly that access thes...
Extracting multiple 3d lengths for lines in AutoCAD 2007
Rick Noel posted a topic in AutoCAD 2D Drafting, Object Properties & Interface
Hi all, This is my first post so please be gentle... I'm trying to extract the 3d length of multiple lines into either a CSV, SSV or directly into a table, I have done a fair amount of research but all of the solutions seem to be for later versions of CAD than the one i'm currently using, I thi...- 6 replies
- 3d line lengths
- 2007
Hi all, new here! I need some help creating and displaying unique IDs for all of my block references in a drawing. I'm self-taught CAD and self taught Filemaker and now I'm trying to figure out how to get the two to work together (I think I can, I think I can). My database is tracking trees and...
- 5 replies
- data extraction
- block reference
