Showing results for tags 'custom paper size'.
    • custom paper size ×
  1. I have created a customised paper size in page setup (3000X900mm); the viewport is a clipped polygon which was chosen as I wished to create a small legend in the bottom corner. Although the drawing has only 1 viewport, when I attempt to plot, the console reads "plotting viewport 2" and nothing a...
  2. I'm still running AutoCAD 2002. I have an HP Inkjet 7000 that is capable of printing borderless 13x19. I want to use it to print half-size sets - accurately scaled - of ARCH-D. i.e. borderless 12x18. I've named a plotter configuration "HP7000 Half-size" and I'm trying to use the Add-Plotter Wizard t...
