Showing results for tags 'curved surface'.
Hi everyone i'm having issues on applying a decal on an inclined surface using inventor here's a screenshot to let you understand my situation. Using the decal tool I cant select the surface on where i put the image (the selected one, to let you understand) Thank you for the help
Hi, This should (on the face of it, parden the pun) be an easy task. I created a lofted surface over 3 scketched lines. The result is a niceCAD Tutor.zip curved surface. I then thinkened the surface and converted to Sheet metal. At this point I expected to just set the sheet metal defaults to the s...
- 3 replies
- surface
- flat pattern
