Showing results for tags 'cui icons'.
Replacing CUI (acad.cuix) on 2nd PC - toolbar icons corrupt
SAFeSTeR posted a topic in The CUI, Hatches, Linetypes, Scripts & Macros
Hi, I have an issue when replacing the 'acad.cuix' on a 2nd PC with my existing one. To do this I literally replace the file on the C:\ drive. I've tried loading my custom file into the CUI but I get an error message: Partial customisation file cannot have the same Customisation Group Name as th... -
Hello, I'm using Map 3d 2012 and trying to insert a shortcut icon(panel) into the INSERT tab on the UI Ribbon for the _MAPIMPORT function. I can't find the function in the list of commands, but the function is available if I type it into the command bar. Can anybody point me in the right direc...
Hi Does anyone have any guidance on how best to take icons from the tool palettes into the ribbon menu ? I am currently going through the laborious process of moving my company tool palette commands into ribbon format..... it would be great to find a quick way to grab our custom icons from t...
