Showing results for tags 'ctb file'.
Hi, Masters lisp is not working correctly? ; error: too few arguments help please
I was working in LT 2014, everything running just fine since we got this version. Then last night I went to plot to a pdf using "monochrome" like I always have, and now it says "monochrome.ctb (missing)". It's the weirdest thing since it worked literally 5 mins before hand. I went thru the autoc...
- 2 replies
- plot sytles
- plot style
File path for pen styles keeps changing
kizaerf posted a topic in AutoCAD 2D Drafting, Object Properties & Interface
Every time I open a new drawing, I have to re link the path for my pen styles (CTB) I have to go to OPTIONS, and re link the path manually every time under 'plot and publish log file information'. It re links to the wrong path by default and I have to change it. is there a way to fix this. it's aggr...- 3 replies
- pen styles
- options
:cry:I use to work for a firm that taught me AutoCAD, I have since left and invested in 2013 version. When we plotted our drawings the line weights (especially on Elevations) showed great dimension. I have played around to death and just cant get a good CTB file created...... Could anyone share or s...
- 7 replies
- plotting issues
- lineweights
(and 5 more)
I am searching for a CTB file that makes a good variety of line hierarchy. I have recently changed companies and need to set up a new standard for my department. Does anyone have a standard file that they really like and think works well. I am also looking to see if there is a way to print a CTB fil...
- 3 replies
- line hierarchy
- ctb file
