Showing results for tags 'csv file'.
    • csv file ×
Found 6 results
  1. Please, someone help me. I thought my program was in its final stages, but it is not. I used AutoCAD 2002 and 2007 during development, but when I tried to install it in AutoCAD 2021, this happened (see the picture). It prompts as if I need to edit the attributes one by one. Also, how can I eliminate...
  2. please help me write a code. i have csv file contains point, northing, easting, elevation, description. i also have a drawing file that has attributes-point,description,elevation. this drawing file is in a support file search path. i want to make an autolisp that import csv data into autocad. The no...
  3. I'm trying to get a custom association list with the format: ((("TAG1" . "VAL1A") ("TAG2" . "VAL2A")("TAG3" . "VAL3A") ...) (("TAG1" . "VAL1B")("TAG5" . "VAL5B) ("TAG7". "VAL7B") ...) (("TAG1" . "VAL1C)("TAG3" . "VAL3C")("TAG4" . "VAL4C") ...)) So far, I can gene...
  4. Hi all, I need some help with a lisp routine that I'm attempting to write. What I need to do is extract a panel label by selecting the text and then select the dimensions that I need extract, I've managed to extract the dimensions correctly but when the information is extracted I get is "nil" in...
  5. Hi, i'm want to import the code (or description) from csv file (X,Y,Code) on the coordinates of each point. I can do it in excel, but i'm looking for a easy way. The layer could be current, height 2, and rotation 0. I can change this properties later, so no problem about it....
  6. Hi i'm looking for an Autolisp that help me to compile title block starting from a csv file. At the moment I know this Lisp http://www.lee-mac.com/updatetitleblock.html It is exactly what I need. The problem is that this program compile all the block title (present in "model" sheet) with...
