Showing results for tags 'create vertex'.
    • create vertex ×
  1. sample_MPoly2.dwg Hi all, I have six polylines, one of them is closed. I need to create vertices on a closed polyline. The sample drawing is attached. The vertex coordinates to be created are the coordinates of first vertex of other polylines. So far I only managed to store the coordinat...
  2. Hello there, Merry Christmas! I am new in LISP and I don't know where to start from. For clarity, please refer to the snapshot provided. I am not quite familiar with AutoCAD terminology though, but I'll try to explain my problem clear. Basically, we have polylines and points having their...
  3. Hello, there, I am trying to find a LISP routine which will find the closest point on a polyline from a selected block reference. This routine finds the closest distance between two objects by selecting both objects, but it does not seem to work with block reference. After it finds the closest...
