Showing results for tags 'copy paste'.
dynamic block Dynamic parameters destroyed when copied to another drawing
grzegorz1928 posted a topic in AutoCAD Drawing Management & Output
Hi, I have a problem with copying a reference to a dynamic block from one drawing to another drawing containing the definition of the same block - their dynamic parameters are not preserved correctly. Comments: If I insert this block into a "clean" drawing, this problem does not... -
In Autocad 2013, when I highlight a drawing in model space and copy, then go to new drawing and paste to original coordinates, everything comes in fine except for blocks. the blocks get thrown far away from everything else. can anyone help
- 13 replies
- copy paste
- blocks
Hello; I am having trouble with blocks that I am not using anymore in my file. I have inserted blocks from other files using design center, dragging it to my new file. In my new file I exploded the blocks. It doesn´t let me purge it, and it still appears in the design center of my new file, event...
- 6 replies
- design center
- copy paste
