Showing results for tags 'coordinate systems'.
Creating custom coordinate system (with datum parameters TOWGS)
Kevin Malone posted a topic in Civil 3D & LDD
I'm tying to create custom Coordinate System in C3D 2012 with datum parameters (Dx, Dy, Dz, Rx, Ry, Rz and scale), but during the creation process (thru MAPCSCREATE function) I don't get anywhere to input this values. As you can see on screenshot, TOWGS parameters are all "0". Only way t...- 7 replies
- c3d survey
- c3d
Plotting Latitude and Longitude in Vanilla ACAD 2014
dal-designs posted a topic in AutoCAD 2D Drafting, Object Properties & Interface
OK, so I'm an experienced CAD user but have never had to do anything but draw by metes and bounds before, so I need some direction here. I am trying to draw the location of a proposed driveway in vanilla AutoCAD 2014 in such a way that I can bring it into QGIS and/or Google Earth and lay it righ...- 4 replies
- qgis
- coordinate systems
In Civil 3D, under the Insert tab, there is a menu selection that allows you to insert a Google Earth image directly from Google Earth. This image is inserted to match the coordinates of your ACAD drawing. However, it does not always match the known correct line work, depending on the drawing sett...
- 6 replies
- civil3d
