Showing results for tags 'contour flange'.
    • contour flange ×
  1. How do you define the thickness of the sheetmetal when creating a sheetmetal part? My text refers to a Thickness Parameter Value which I cannot find in Inventor 2015 Contour Flange. I want to create this item in 10mm plate but I cannot even set it to 1mm sheetmetal. Is there any limit of sh...
