Showing results for tags 'content center'.
Hey guys, how do you set up your content center so it works at work AND home? I have some some custom bolts and other fasteners I use with simplified names so on the BOM I don't have to change a ton of descriptions and what not (I like it to say SHCS not the entire thing, things like that). Well, I can drop in a bunch of bolts in my assemblies, to then not be able to resolve the link at home. I've tried copying and pasting my folder onto a thumb drive and taking it home, and pasting on top of the libraries folder and had them merge. No luck. Still have broken links when opening the assemblies I placed the bolts in at work. Any suggestions would be appreciated! Edit: What setup drops a copy of the bolt into my project folder? Is that where the "As Standard" and "As Custom" come into play? Not the best solution, as it would make my files larger, but I guess the customer would then not have any issues opening things if they had Inventor.
My inventor works just fine and I can get to the content center where the list of fasteners, bolts, nuts, etc. and it opens everything. My co-worker does not have this listed in his drop down. How was this switched off/disabled and how would he get this back? We don't have this file location linked and if I remember correctly he had it at one point last year. Everything I have read points to the vault but we have never used it or ever logged into anything with inventor. When I tracked the "family" files on each of our desktops it appears that I have many and he has few. Any help would be appreciated as right now we open the content center on mine, save as copy to the shared server and he opens it from there, not the best way to do things.
Hi All, Good day I have prepare my questions in powerpoint format so that to explain it better with photos Please link to my google drive due to file size more than 500K limits. https://docs.google.com/file/d/0B4tE3sKkl4AnUEx4YUlQRzJwTWs/edit?usp=sharing Thanks for helping
I have been stumbling through creating new families in content center on and off for the past few months. I recently created a new Family with a part that I drew up. Since this went fairly easy I decided to keep going while everything was fresh in my head. Now I am stuck again. I want to create a new family called "Nipples" in the Tube & Pipe category. When I publish my sketched part I cannot select or create a new family in that category. If i create a new category called Nipples in the Tube & Pipe category all the parameters are also copied. I do not want this. Now, I can create what I need fine if I create an entire new category but I want this to be a family in the Tube & Pipe category. Does this make sense to anyone? I tried to explain as good as I can but I am getting frustrated with the forum at AutoDesk where I really never get my questions answered. I am using Inventor 2013.
- 2 replies
- create new
- content center
