Showing results for tags 'construction line'.
    • construction line ×
  1. I use a the XLine command frequently when I draft to temporarily define some geometry, and then I Erase the construction lines shortly thereafter. Recently, I’ve been wondering if there is a way to make it so that every time I draw a construction line it is the same color. I understand that I could...
  2. I have noticed that users often draw a diagonal construction line across a feature and specify a midpoint on it like so: What is this for? What is the advantage?
  3. Hi, Is there a way for me to get,customize or import the regular linear construction line? for example: if when i need i just click on the construction line tool and it will work either vertical or horizaltal, i used to be able to do in different version of cad but not on this 2010 autocad that i h...
