Showing results for tags 'commands not working'.
Okay, so I am not sure how I did this, but I have some how disabled the resultant, answer and/or echo at the command line. When I am trying to debug and test some lisps at the command line, I don't get any answer. For instance if there following were entered at the command line: Command: (S...
- 1 reply
- commands not working
- commandline
Halfway through the day today a few things changed it wht I am able to do in AutoCAD. These are all things I was able to do earlier in the same drawing. - I can no longer double click text to edit - i can right click a block but the option to edit-in-place is not there - select objects before...
Some AutoCAD dialogue box's don't apprear
jaylo23 posted a topic in AutoCAD Bugs, Error Messages & Quirks
Hello all, i have had this problem for some time now, but im just now getting time to post it. Basically the problem i have is that certain AutoCAD commands, not all, that require a dialogue box do not work, i.e insert, drafting settings, linetype settings, etc. When i invoke the command AutoCAD j...- 16 replies
- command freeze
