Showing results for tags 'command reactor'.
    • command reactor ×
  1. So I want to be able to set things inside functions when the command is called up in the command line. I tried using a command reactor. It works fine when it is outside of the function that I wanted for it to be activated but when I put it inside the function, it doesnt seem to be getting the values...
