Showing results for tags 'command line'.
    • command line ×
Found 9 results
  1. Please help me with this; While picking points, the data/text in the command line gets wrapped even though there is more space. (defun c:nanpt () (vl-load-com) (princ "\nStakeout Point by: Nan Glase (2024-12-24)") (princ "\nEnter \"NANPT\" to run.") (setq...
  2. I'm posting this for any future people encountering the same issue. Hopefully it will save them some frustration! I'm old and I like the Command Line under the tabs. Personal Pref... I tried letting it float and adjusting transparency settings for several months and I'm just an old dog....
  3. Dear Members, I have some stretchable dynamic Blocks. I would like to insert and change the length of them in command line. (without use my mouse and grip points) i havent got any problem with the insertation but i cant change the length of this bloks without using mouse. in Properties wind...
  4. Has anyone had the issue of your command line not working if you have a p-line/object selected and your cursor is over the same object? sometimes this will cause the object to adjust after you try to start a command, but the command won't start. I just get a beep signaling an error, but no message...
  5. Hi, is any way to get command line status by programming in visual lisp? I.e. finding whether command line is: on (visible) or off (invisible) floating or docked (fixed) I appreciate any help.
  6. Can I modify an existing viewport in a macro or in the command line? Using a macro, I want to modify (specifically delete) the viewport from a layout tab after chspace from model space. Does anyone know how to do this? I have LT so no LISP. qselect works but cannot be put into a mac...
  7. I have dual monitors . today i tried maximized space on main monitor by placing command line on 2nd screen . Strangely when i do that , autocad is slowed down . any command has a lag of about a second . i usually have adcenter and toolpalettes on 2nd monitor with no problem . any idea why thi...
  8. Hi, I have created a macro command for my "dimaligned" so that every time i click on macro button and create a dimaligned it turns onto the good layers and i wanted to know if it is possible to remplace or create another dimaligned shortcut command (dal) by that macro command that i created. So eve...
  9. VisionSurvey
    Command Line Options Not Showing
    Hi All, I'm trying out AutoCAD 2011, it's looking great - but I seem to have lost any options/toggles to commands in the command line. For example if I type 'zoom', I'd expect to see extents, window, all etc appear but they dont - I am just left with 'zoom' and a blank space. The options...
