Showing results for tags 'closed polyline'.
    • closed polyline ×
Found 5 results
  1. Hello everyone. I tried to do it but simply don't have the knowledge to make it. I'm in need of lisp where I select two polylines and the lisp creates closed polyline on current layer, using those selected and leaving them in drawing. Now the trick is on each side the shorter polyline must...
  2. sample_MPoly2.dwg Hi all, I have six polylines, one of them is closed. I need to create vertices on a closed polyline. The sample drawing is attached. The vertex coordinates to be created are the coordinates of first vertex of other polylines. So far I only managed to store the coordinat...
  3. Ok, so this pesky polyline won't give me an area. I found a topic on the Map 3D forum that had a couple of suggestions, but I'm using vanilla AutoCAD 2014. As you can see by the image, the area value for this polyline is missing. I've tried flattening it (as there is a survey attached with 3D p...
  4. Hi all, Got what I think is a dumb question I've been scouring for two hours. I use Civil 3D to create photomasks. It involves creating a lot of complex closed polylines that are filled during the conversion process to files such as GDSII. What I'm trying to do is use the Plot function to ge...
  5. Hi All, We need custom program to extract coordinates from a multiple closed Polyline and the text available within the closed polyline. Sample drawing and required output (CSV file) based on the sample DWG is attached herewith for your clairity. Layer Object text (inside closed LWPolyl...
