Showing results for tags 'civil 3d 2013'.
    • civil 3d 2013 ×
Found 6 results
  1. Good morning, I've created quite a number of tool palettes, including nine palette groups, and everything has been working great. Now, of a sudden, I can't drag and drop any type of entity into an new, empty palette. I can still load whatever I want into an existing one, but nothing into a ne...
  2. Good morning, I've created quite a number of tool palettes, including nine palette groups, and everything has been working great. Now, of a sudden, I can't drag and drop any type of entity into an new, empty palette. I can still load whatever I want into an existing one, but nothing into a ne...
  3. Hello, I am trying to add a bend to my leader lines using Civil 2013. I have attached two images the first one is of my standard leader (dimension is inline with the leader line), the second one is a leader I "faked" to illustrate my desired leader style, a perpendicular leader then a bend to so...
  4. Tad_Thurston
    Middle mouse button problems
    When going from ACAD Civil 3d 2011 to Civil 3d 2013, my mouse middle button (scroll button) stopped working correctly. I have verified that it still works properly in the 2011 version. Before the software upgrade, rolling the middle button zoomed and if I clicked and held down the middle button an...
  5. Tad_Thurston
    ACAD Civil 3D Google Image Import?
    Don't know why Autodesk decided to take away a nice feature but the 2013 version of Civil 3D does not have the import Google Earth image pull down window like the 2011 and 2012 versions had. Anyone know how to do this and keep the location of the image in the same coordinates as your drawing? The...
  6. We have our CTB files (as well as our pmp and pc3) files on the network. With 2008 thru 2012, we have edited our profiles to point to these. In 2013, one C3D PC sees them fine. A second C3D PC and a LT PC see the lone STB file and no CTB's. It appears the pmp and pc3 files are seen, however. I di...
