Showing results for tags 'changing values'.
    • changing values ×
  1. ctapia1311
    Toolbox - Changing values
    Hi Guys... I would like to know if is it possible to change or add a configuration of the SoliWorks Toolbox. For example if I set a Socket Head Cap Screw M4 in de Design Library and I need a lenght larger than the maximum (40mm). What can I do??? Is it possible to modify this values for dif...
