Showing results for tags 'center object'.
    • center object ×
  1. Hello all, I have a dynamic block with a problem. The block can now stretch and rotate, but in the center of the block there is an object that should always be in the center of the lines. How does this needs to be done? Can it be without parameters to? Kind regards, D.M. Str_Ro...
