Showing results for tags 'cad lt'.
    • cad lt ×
  1. I'm trying to write either a script or a macro to make it easier to do an array that we will need to replicate on a regular basis. Basically, I want a path array to offset mtext every 20m along a centreline. If I do this in the command line, it's fine: ARRAY select object PA [path] selec...
