Showing results for tags 'cad 2013'.
    • cad 2013 ×
Found 4 results
  1. Ninjanine
    A newbie here!
    I truly believe that there are more things i need to learn in AutoCad. Doy you have any tips you can share with me? Don't be shy and let's be cad buddies!
  2. GregD
    CAD LT 2013 Block Authoring
    Hi, It's a bit difficult to explain my problem I would like to know how (or if it's even possible) to have an object follow a block in rotation (authored) without the object rotating itself. Kind of like a piston in a car, the piston will only move up and down but the rod and crankshaft will...
  3. DJRandall
    Questions!
    My friend is wanting to know the answers to these questions? 1a What is the advantage of creating a Block for use in an AutoCAD drawing? 1b Why is it recommended to draw Blocks on Layer 0? 2a What is the difference between a Block and a WBlock?...
  4. I'm trying to use the PATH array feature on 2013 to array stairs, and I can't get the array to be 100% accurate. It seems like CAD rounds the decimal to the nearest 3/4" which could be causing the problem. I set my run to 10.5" and rise to 7.25", array along the angle of the stringer, and there's...
