Showing results for tags 'c++'.
    • c++ ×
  1. I am trying to decal sketch on mesh using exponential map. While generating exponential map, I am calculating plane by initial point on mesh and normal calculated on mesh by that point. then algorithm calculates nearest vertices from that point and traverse to them by edges. Then Edges are projec...
  2. Hi everyone, I was wondering if I can run a lisp in AutoCAD from building (running) a C++ code in Visual Studio. What I mean is can I have AutoCAD open and run a C++ code in parallel and have the lisp loaded automatically in AutoCAD? The lisp I want to use is 'ascpoint', which gets a text file...
