Showing results for tags 'break plines'.
    • break plines ×
  1. Suppose you have a list called ptlist that consists of points (i.e. (x, y, z) coordinates), and a polyline entity called pline. Not assuming that all these points are on the pline, can you recursively try to (command "break" pline) and subsequent resulting entities. I'm trying out the logi...
  2. AutoCAD Map5 Hoping for a routine (or two or three) that will: 1. Convert all Lines/LWPOLYLINES/etc to Plines (no object data on the layers I need converted) 2. BREAK each Pline at the Insertion points of EVERY instance of two different blocks that are inserted along the lines. 3. Insert TEXT...
