Showing results for tags 'bounding box'.
    • bounding box ×
Found 4 results
  1. Hi all, I am attempting to get a viewport from blocks in modelspace to paperspace with a layout template. I would like this automated by selecting all the blocks in numerical order and placing them on the correct numbered layout. I have found plenty of lisp out there, but nothing that seems to work...
  2. I currently have a really really basic LISP routine. It was written to center a group of objects within a 12x9 drawing sheet (some people do not care whether their drawing is centered or not... pet peeve) ANYWAYS.. In a nutshell it prompts user to select objects using SSGET. Then asks the user f...
  3. Hi, I'm looking for an autolisp that can create a rectangular bounding box around a closed object i.e a region, a block of a profile, an open-closed polyline. Thank you in advanced, Nicolas.
  4. Hi, I am looking for a way to automatically draw a rectangular/square frame around a block (in this case, a block of a profile) and also set the base point in the middle of the profile block. I have to use xline together with rectangle to do this, then draw a diagonal and use the midpoint o...
