Showing results for tags 'blocks wont insert'.
Invalid Error: Cannot insert blocks or copy and paste into the drawing
ljhignett posted a topic in AutoCAD Bugs, Error Messages & Quirks
Hi, I work at my local council as a trainee engineer, we recently recieved a drawing back from a consultant. Being the trainee i have to 'fix' it. The issue is when i try to insert our own blocks ie (title block) it comes up with invalid and wont perform the command. Same thing if i try to copy...- 3 replies
- error
- copy paste errors
for example when i click on "Door - Imperial" i get the message "Source drawing "C:\Program Files\AutoCAD 2010\Sample\Dynamic Blocks\Architectural - Imperial.dwg" for block "Door - Imperial" not found." what do i need to do to fix this???
Hey all, I have a quick question. I apologize if this has already been asked, but I can not find it myself. I have searched other spots, but its hard if the thread does not specifically deal with your question. My problem is, we have a LISP routine at my company. After you get all of the informa...
- 27 replies
- blocks wont insert
- autolisp
