Showing results for tags 'blocks attributes'.
Blocks attributes with fields OR Mtext with fields
Kraken posted a topic in AutoCAD 2D Drafting, Object Properties & Interface
I've been searching for an answer to this question: What if any is the advantage of placing fields in Block attributes Verses placing the fields in Mtext for the same purpose( think title bock info and numbering)? My initial thought is that it's just two ways to skin the same cat. HOWEVE... -
Dynamic Block Attributes not Moving/Rotating When Locked
jarr3tt88 posted a topic in AutoCAD Drawing Management & Output
Hopefully someone can help me out there that is much more experienced. I thank you in advance for any help provided! The drawing: I have created a dynamic block (see attached below) I have two versions in the drawing, one that is setup using text, and the other using attributes. The text version...- 13 replies
- dynamic blocks
- blocks attributes
Automating tasks for swiftness and presentation purposes using Blocks and Tables
LesCarpenter posted a topic in AutoCAD Drawing Management & Output
I was wondering if anyone can help with problem I have. I am using Autocad 2011 although I only use it to tidy my drawings prior to sending to my client, my proficiency is quite basic. I have been tasked with surveying a number of feeder pillars or cabinets with 5 points of data, pt 1 is the centre...- 3 replies
- presentation
- blocks attributes
Morning Everyone, I've just won a fabulous project with a very well known supermarket producing phasing drawings for their new store fit-outs; I receive their drawings in DWG format with as you can imagine thousands of blocks detailing the shop fixtures. Each blocks contact a minimum of 5 attri...
- 13 replies
- attribute value
- attribute edit
Hi, When i use the command -attdef: -ATTDEF Enter an option to change [Invisible Constant Verify Preset Lock position Annotative Multiple lines]: so i can toggle the invisible mode with the code (command "-attdef" "I" "" ... ) now i would like to check te current state...
