Showing results for tags 'block reference'.
import csv file into autocad using autolisp and block reference (part2)
NanGlase posted a topic in AutoLISP, Visual LISP & DCL
Please, someone help me. I thought my program was in its final stages, but it is not. I used AutoCAD 2002 and 2007 during development, but when I tried to install it in AutoCAD 2021, this happened (see the picture). It prompts as if I need to edit the attributes one by one. Also, how can I eliminate... -
please help me write a code. i have csv file contains point, northing, easting, elevation, description. i also have a drawing file that has attributes-point,description,elevation. this drawing file is in a support file search path. i want to make an autolisp that import csv data into autocad. The no... -
Hello, I was getting a drawing that I have to modify. The problem is, that in this drawing are several block references with the name. I.e. I have about 100 block references calling "WcLux" . Is there a possibility to make the name of the block reference unique with a script: WcLu...
Closest point on a polyline from a block reference
jes_g posted a topic in AutoLISP, Visual LISP & DCL
Hello, there, I am trying to find a LISP routine which will find the closest point on a polyline from a selected block reference. This routine finds the closest distance between two objects by selecting both objects, but it does not seem to work with block reference. After it finds the closest...- 7 replies
- point on polyline
- create vertex
I have recently downloads a pile of files, blocks for inserting, symbols. Apparently all files have block in them of the same name of the file name. Thus, upon inserting a file I get the error "block reference itself" and will not insert. Is there a means of removing the block in the file in a...
- nested
- block reference
Pasteclip is pasting everything as a block reference
aosp posted a topic in AutoCAD Bugs, Error Messages & Quirks
I'm using AutoCAD 2015 on a 2D drawing, and usually use CTRL-C and CTRL-V for my copying. Today, for some reason, everything I copyclip and pasteclip comes out as a block reference. It happened first with a single-segment polyline, then I tried a few other objects - dtext, rectangle, closed polyline... -
Updating block references.
SAFeSTeR posted a topic in AutoCAD 2D Drafting, Object Properties & Interface
Ok so here's the situation... I have approx 150 files all with multiple layouts, each layout containing a legend block that needs updating. I edited the existing block and used WBLOCK to save it out ready for use in the other drawings. When I try to insert it into another drawing it gives me... -
How to make double clicking on a Block to open the in-place editor
petsagouris posted a topic in AutoLISP, Visual LISP & DCL
I have followed the article about Using the In-Place Block Editor (REFEDIT) and I now need the macro to press the "Ok" on the Refedit confirmation dialog automatically. How would I go about that? -
Hi all, new here! I need some help creating and displaying unique IDs for all of my block references in a drawing. I'm self-taught CAD and self taught Filemaker and now I'm trying to figure out how to get the two to work together (I think I can, I think I can). My database is tracking trees and...
- 5 replies
- data extraction
- block reference
