Showing results for tags 'block position'.
    • block position ×
  1. Hi, i need this block point. please see attached file.
  2. I have an idea for scheduling our plant’s production but I don’t know if it is possible. I would like have your input. We use AutoCAD 2011 and AutoCAD LT 2011. We also use Office 2010. I have some experience with Visual Basic. Here is the problem: We use Excel to schedule production...
  3. What is wrong in the code? I am trying to set the Z position value to zero for all the blocks in the drawing; (defun c:B0() (setq myFilter(list (cons 0 "INSERT"))) (setq ss (ssget "_X" myFilter)) (setq l (sslength ss)) (setq i 0) (Repeat l (setq blk (ssname ss i)) (setq DXF (entget...
