Showing results for tags 'block library'.
Redefining Blocks when inserting into a drawing from a block library.
sarah.casey@ffeconsulting. posted a topic in AutoCAD Drawing Management & Output
Hi all, If I edit a block definition in one file, is it possible to update all instances of the block in another file? I have tried to insert my updated block definition into another file where the block is used multiple times, but it just inserts it as the old definition in that drawin...- 13 replies
- wblock
- redefine block definitions
Hi there, So my job would like me to create a usable library of products to make things easier. We make custom cabinetry, but there are many more standard sizes that may be useful. I'm vaguely familiar with creating blocks and saving, but I'm trying to find out if there is a good way to go about ma...
- 5 replies
- edit blocks
- edit
Insert Blocks at Insertion Points of Selected Characters
nick777 posted a topic in AutoLISP, Visual LISP & DCL
Right now I have 15,000 drawings that use letters instead of symbols, an artifact of a now defunct CAD software that translated the letters into symbols. I'd like to remake this in AutoCAD by inserting blocks at the location of those letters. I cannot find instructions on how to do this anywher...- 6 replies
- block library
- block insert
Hi, I am looking for LISP application that can do the following: 1. Manage a Library of Blocks (the blocks can be of two types: a drawing with numerous blocks or a folder with each block written to a dwg file) 2. Open a Block and turn first-level elements color and linetype to BYBLOCK...
