Showing results for tags 'block insertion'.
    • block insertion ×
  1. When I try to insert my very basic block into a certain drawing, I get this message in the command line: Command: _insert Substituting [romans.shx] for [au102s01]. Substituting [romans.shx] for [205A1502.shx]. Substituting [romans.shx] for [205A1501.shx]. Substituting [romans.shx] for [205A150...
  2. Hi, i export from arcGIS server shape files, then i import them with object data using drawing layer and "use data field for layer name". I get layers created by "codes". After that i use LAYTRANS to translate layers to my own created layers. So my question - is there any way to automatically inser...
  3. Does anybody have any idea if a lisp routine can be created so that if a block (detail .dwg) is inserted from a detail library that a hyperlink can be added to the block as it is being inserted so that the hyperlink can be used to later open the detail.dwg in it's remote location. We're looking...
