Showing results for tags 'block insert attributes'.
    • block insert attributes ×
  1. Hi, I'm working on a project in which we have a large volume of drawings, there's information in the title block that is required to be changed on regular basis. Would anyone know if there is a quick method to doing this. I've tried a few things I've found on other forums but they didn't wor...
  2. I was wondering if anyone can help with problem I have. I am using Autocad 2011 although I only use it to tidy my drawings prior to sending to my client, my proficiency is quite basic. I have been tasked with surveying a number of feeder pillars or cabinets with 5 points of data, pt 1 is the centre...
  3. Hi, I've been trying tons of different solutions to solve this problem: insert a block that has an attribute which happens to be the last object id. This is the best code I tried so far but without any succss. (defun c:q1() (command "_.PLINE") (while (= (getvar "CMDNAMES") "PLINE") (command...
