Showing results for tags 'block insert'.
Insert Block in-between two Points using Autolisp
subodh_gis posted a topic in AutoLISP, Visual LISP & DCL
Many a times it requires to show the same block with different angle and scale. Rotating each block to a required angle, and scaling it as required will take a lot of time so can we Insert Block in-between two Points in the angle and scale of points selection using Autolisp . I am using AutoCAD 2004... -
Block Library only partially loading! Help!
Pander93 posted a topic in AutoCAD Bugs, Error Messages & Quirks
I made a Block Library with 4 objects in it, which I proceeded to insert into a drawing. However, only 2/4 of the objects inserted. The layers are not frozen, locked, or invisible. I've attached two screenshots. Please help me! I've been messing with this for hours.- 6 replies
- block attribute
- block
Autocad Block Replacment
jaycopes posted a topic in AutoCAD 2D Drafting, Object Properties & Interface
Hi All, I hope i have put this in the right section of the forum. Introduction to my Queries: I am working on a 2D housing layout, which has multiple houses, roads, paths and trees, ect. For the record I use Blocks for the houses and within each block contains details such as House Name, Engi...- 3 replies
- block insert
- block attribute
Does anyone know how to update a block already present in a drawing with a block pasted from another drawing. I cannot use insert block with a file named the same as the block in the current drawing because the pasted block (of the same name) contains a visibility parameter that if I explode bef...
- 3 replies
- overide block
- inserting blocks
Insert Blocks at Insertion Points of Selected Characters
nick777 posted a topic in AutoLISP, Visual LISP & DCL
Right now I have 15,000 drawings that use letters instead of symbols, an artifact of a now defunct CAD software that translated the letters into symbols. I'd like to remake this in AutoCAD by inserting blocks at the location of those letters. I cannot find instructions on how to do this anywher...- 6 replies
- block library
- block insert
Block Insert, Center and Auto Fill Attribute values, by clicking two points input
jfklimek posted a topic in AutoLISP, Visual LISP & DCL
I'm having trouble finishing this LISP. Can anyone help me out. The command line is telling me the command I'm entering 'roomtag' is unknown. It's probably something little but I can't seem to figure it out. Please help out if you can. Thanks! ;;;Place Room Tag in Middle of Room and Auto Fill...- 11 replies
- block insert
- attribute field
insert block at distance & angle from first block, then repeat until stopped
BudPerry posted a topic in AutoLISP, Visual LISP & DCL
In this portion of a continuing program I'm putting together, a 4' block is inserted at a user point at a defined angle, then it is again inserted but this time 4' away at the same angle so that the two blocks form an 8' line. This is continued until the user stops the program. However, when the sec...
