Showing results for tags 'block editor'.
ADJUSTING FULLY CONSTRAINED ADCentre BLOCKS
Thando posted a topic in AutoCAD 2D Drafting, Object Properties & Interface
I am trying to adjust a block that I got from the AutoCAD Design Centre to my specific length but it would only grow / scale to its preset constraint measurements, EXAMPLE I want 2000 units but it has options of 1008 and 2016 units. Will Block Editor help me, maybe? AutoCAD 2015- 2 replies
- constraints
- blocks
Hi, It's a bit difficult to explain my problem I would like to know how (or if it's even possible) to have an object follow a block in rotation (authored) without the object rotating itself. Kind of like a piston in a car, the piston will only move up and down but the rod and crankshaft will...
I have some dynamic blocks in an old file. I am trying to use the same blocks in another file with some modifications. But when i try to edit it in block, it still remains the same. Can anybody guide how this is possible or what command I should instead of Bedit?
- 8 replies
- edit
- block editor
Editing information in title block on multiple drawings layouts
timmy2f posted a topic in AutoCAD LT
Hi, I'm working on a project in which we have a large volume of drawings, there's information in the title block that is required to be changed on regular basis. Would anyone know if there is a quick method to doing this. I've tried a few things I've found on other forums but they didn't wor...- 2 replies
- block editor
- block attribute
Hi all, here Iam attaching a drawing which I need to edit the text. If I explode the block all are coming with lines and arc...do you have any solution Test.dwg
- 2 replies
- explode me this dwg
- block editor
Drawing 'lags' after using block editor
SAFeSTeR posted a topic in AutoCAD Bugs, Error Messages & Quirks
Had this problem for a while now, however, I have managed to solve it so thought I would share it. Not sure if it is a common issue and I currently use AutoCAD 2012. As the thread title suggests, sometimes after exiting the block editor, my drawing begins to 'lag'. It becomes very choppy when pa... -
MLeader with [ATTRIBUTE]
aehlers posted a topic in AutoCAD 2D Drafting, Object Properties & Interface
I'm struggling to create an MLeader object with MText: \LCONSTRUCTION NOTE:\l\P[ATTRIBUTE] I wish to: 1) use command "ATTOUT" to create a text file "[drawing]ATTOUT.txt" in the drawing folder (in Windows Explorer) containing a seperate block named "POINT" with attribute [POINT] and MLea...-
- attributes
- attout attin nested
Hi all. I think a setting changed on my pc this weekend. I used to be able to double click the block and edit the attributes in the editor. Now, I can't change any values. I can only get to the dialog that shows info on the block and when I right click, I only have a few commands come out of the fly...
Hi, new here, so hello all I would like to know how to turn off hatching using the block editor. thanks in advance Loopy121
Edit standard blocks and symbols (MEP 2012)
sinbad92 posted a topic in AutoCAD Drawing Management & Output
Hey I am struggling to edit the standard set of blocks that comes with AutoCAD such as receptacles junction boxes etc. I want to edit the standard blocks and then save my changes for future use. Right now the blocks come in at different sizes then I would like. I try to edit them in the block editor...- 2 replies
- electrical
- dynamic
Block Flattening/ how to enable UCS within a block
Kepners posted a topic in AutoCAD Bugs, Error Messages & Quirks
Block Flattening/ how to enable UCS within a block. I am working on a job that has hundreds of blocks added which have various random z-axiz added. I have been in to the block and tried to Flatten it... I get a forced error returned saying "unable to flatten block z-axis isnt enabled in block ed...-
- superflatten
- flatten
