Showing results for tags 'block dynamic property'.
Crosshatch in dinamic block
studiostt posted a topic in AutoCAD 2D Drafting, Object Properties & Interface
Hi, I have a problem with the creation of a crosshatch in a dinamic block. In particular, I have to make a crosshatch between two circles that change radius with a non linear function, but I'm not able to do it. Can someone help me? -
Hello, I am trying to get two lines to rotate about two opposing circles whilst being able to stretch and also being joined together at opposite ends to the circles , so they can be controlled with one grip at the apex. I have been able to have the one set to work as i wish, but I can not get it to work for both at he same time. I can move the two lines as I wish that are not in a block, but can not get the lines to rotate about a circle, only at the start point. Any ideas or solutions would be greatly appreciated I feel like I have tried everything. Thanks. a.dwg
- 3 replies
- grips
- dynamic stretch
How to make an existing block annotative
Benjo posted a topic in AutoCAD 2D Drafting, Object Properties & Interface
Hi, I created an dynamic block few weeks ago and forgot to make it annotative. I try the ddchprop command, switch annotative to yes but it automatically immediately switch back to no. Could anyone help me with this please?- 2 replies
- block dynamic property
- block annotation
- (and 3 more)
Hello, Simple question. Is it possible to get dynamic properties from AcadBlock not AcadBlockRefference? As I didn't find any solution, I implemented this function: Private Function ExistsDynPr(bb As AcadBlock, PropName As String) As Boolean Dim oProps As Variant Dim oDblkProp As AcadDynamicBlockReferenceProperty ', ap As AcadDynamicBlockReferenceProperty Dim I As Integer, pp(0 To 2) As Double, abr As AcadBlockReference Set abr = ThisDrawing.ModelSpace.InsertBlock(pp, bb.Name, 1, 1, 1, 0) 'bandom iterpti [laikinai] ExistsDynPr = False If abr.IsDynamicBlock Then oProps = abr.GetDynamicBlockProperties For I = 0 To UBound(oProps) Set oDblkProp = oProps(I) If oDblkProp.PropertyName = PropName Then ExistsDynPr = True abr.Delete Exit Function End If Next End If abr.Delete End Function Is there any side effects or risks of inserting block? If no I'll stick to this function, though I think it's not very nice solution.
