Showing results for tags 'block annotation'.
Autocad Block Replacment
jaycopes posted a topic in AutoCAD 2D Drafting, Object Properties & Interface
Hi All, I hope i have put this in the right section of the forum. Introduction to my Queries: I am working on a 2D housing layout, which has multiple houses, roads, paths and trees, ect. For the record I use Blocks for the houses and within each block contains details such as House Name, Engi...- 3 replies
- block insert
- block attribute
Hi all, I need to accomplish the following: Place a block labelled AB-101 on layout 1 the same block labelled A-101 on layout 2 and the same block labelled B-101 on layout 3. Any suggestions for doing this more efficiently than creating three separate layers, and three separate copies of...
- 7 replies
- block annotation
- block
How to make an existing block annotative
Benjo posted a topic in AutoCAD 2D Drafting, Object Properties & Interface
Hi, I created an dynamic block few weeks ago and forgot to make it annotative. I try the ddchprop command, switch annotative to yes but it automatically immediately switch back to no. Could anyone help me with this please?- 2 replies
- block dynamic property
- block annotation
- (and 3 more)
Hi all, I am trying to extract data from a block for eg. area of a polyline (that had been made as a block) so that I can export it as an excel schedule. I have been unsuccessful so far. Whenever the data extraction window asked for what kind of information to be extracted, area is not one of th...
- 1 reply
- blocks data extraction
- blocks
- (and 3 more)
