Showing results for tags 'bending in 3d'.
I would like to bend something flat using the flex tool. With the help of tutorials, I have already been able to bend one of the angles(angle a at 90°) but then I cant bend the others because the axis and planes shift afterwords....Does anyone have any advice? Here is pdf that shows what I want t...
- 4 replies
- flex
- bending in 3d
Hello, maybe anyone can help me, with bending command in 3D sketch. Problem is that I need bending from exact point, but i get in that exact point, the middle of bending arck, not at the start. I make two sketches in 2D, and then in 3D make command "intersection curve", and then make these bendings...
