Showing results for tags 'batch plot issue'.
    • batch plot issue ×
  1. Help!!!!! I have just switched over to 2014 and i cannot for the life of me get my batch plot to plot PDF's to a single file! Instead, it's printing all 37 layouts separate. I tried switching between multi-file & single file in the publish options, but nothing! I cannot remember what the tric...
  2. Ok I can not seem to find anyone else having this issue anywhere on the net. I am currently setting up a sheet set within one file where the main layout out is an xref with desired information drawn over the xref. I will need to setup a total of 30 some sheets(tabs) with 3 viewports on each she...
  3. When I use batch plot to pdf file, i get a nice small pdf with layer information which is nice to have. The problem is this pdf when put in a folder that is a shared folder the other computer does not have permission to open or attach the file. In our office I do the drawing and printing of she...
