Showing results for tags 'batch plot'.
Hi there, I'm trying to convert a few thousand files from dwg to pdf and I believe I'm on the right track but am a little stuck. I'm attempting to use DWG TrueView though I have limited access to AutoCAD for like template creation and such. I seem to have trouble getting some of them to plo...
- 5 replies
- layouts
- initialize
How to run a lisp across 'all open drawings' ?
bababarghi posted a topic in AutoLISP, Visual LISP & DCL
All, I have two preliminary routines called CA (CloseAll) and PA (PrintAll) tailored for my needs as following: CloseAll: (defun C:CA() (setvar "TILEMODE" 1) (command "._ZOOM" "_Extents") (command "._PURGE" "all" "*" "No") (command "._PURGE" "all" "*" "No") (command "._PURGE" "all" "*" "N... -
how to Batch plot 8.5x11" multiple page all at once in Autocad 2017
Sengna posted a topic in AutoCAD Drawing Management & Output
I have about 25 paperspace layout that were set at 11x17 size, since the paper size does not matter, I would like to batch plot multiple pages all at once to 8.5x11 size, how can I do that? I could n't find what I m looking for on youtube. any suggestion would be appreciated. -
Ok I can not seem to find anyone else having this issue anywhere on the net. I am currently setting up a sheet set within one file where the main layout out is an xref with desired information drawn over the xref. I will need to setup a total of 30 some sheets(tabs) with 3 viewports on each she...
- publish
- batch plot issue
I'm tring to plot 26 or so sheets into a single pdf or multiple pdfs and I get this error every time with no file being created. [/url]Job: - Canceled Job ID: 1 Sheet set name: Date and time started: 5/3/2011 11:48:29 AM Date and time completed: 5/3/2011 11:48:33 AM UserID: RGDC99 Prof...
- 4 replies
- error
- batch plot
Mtext objects randomly not plotted using Batch Plot
spiff88 posted a topic in AutoCAD Bugs, Error Messages & Quirks
I am using AutoCAD 2010 (D.309.0.0) - English Version 3 I have a page setup using Adobe PDF as the plotter. I am using Acrobat 7.1.4 Standard. When using Batch Plot to plot a number of figures together (into a Multi-sheet file) - random Mtext objects will be left off random drawings. If I...- 1 reply
- mtext
- batch plot
