Showing results for tags 'base point'.
problem with displacemet or use first point as displacement in copy, move commands
khoshravan posted a topic in AutoCAD Beginners' Area
I have difficulty on specifying the distance for copy or move commands. It has different options and I have to get my desired result after many try and error. Where can I find a detailed explanation on these commands options? distance, base point and first point as displacement. My exact proble...- 17 replies
- first point
- displacement
Is it possible to apply dynamics to a blocks base point?
SAFeSTeR posted a topic in AutoCAD Drawing Management & Output
Hi, I'm updating my block library with dynamic rotations but I'm having trouble with blocks that do not have base points in their centre's. When I rotate the block the base point grip stays in it's original place. This can be a problem when I need to copy multiple instances of the block within t...- 6 replies
- dynamic blocks
- base point
UCS base point all over the place when placing blocks made in past versions
pattyandme posted a topic in AutoCAD 3D Modelling & Rendering
Autocad 2013 in model work area , I am having a problem with selecting blocks from the pallet and placing them on the drawing. most were set t0 place at the selected point. how ever i don't know where to begin it will place them at x,y but not at z, ends up out of frame. in front view i place the bl...- 1 reply
- base point
- autocad 2013
Has a Lisp changed ucsicon settings or Insbase? r.e. GeomCurve
whatwillhedo posted a topic in AutoCAD Bugs, Error Messages & Quirks
I am (repetitively) cutting with ctrl+x lines from one objects ucs to another. Since looking at GeomCurve (I think?) I can no longer paste with the objects base point (UCS 0,0,0) . This appears to have stuck with the WCS (when a line is cut using the UCS and origin on the line). On investigation Ins... -
Hello, I'm trying to make blocks with attributes and i watched video on youtube to do so .But when I insert the same block I need to name the tags twice. I don't know how it happens and it bugs me. Please help! A second question is that when I load the block in another dwg file, the base poi...
- 5 replies
- block attribute
- basepoint
Hi everyone, I ran into a weird issue when I tried to create a rectangle off of a base point. Whenever I type in the x and y coordinates, a rectangle is created however the coordinate i typed in is now the end point and the rest of the rectangle extends to the bottom left of my screen and is be...
- 9 replies
- coordinates
- base point
