Showing results for tags 'background mask'.
Backgound mask showing in some viewports on plot
jkoll66 posted a topic in AutoCAD 2D Drafting, Object Properties & Interface
Hi, I have a drawing that incorporates a number of Multileaders that consist of a rectangle with some text inside and a background mask. This drawing is then Xref'd into another drawing.The issue I'm having is that in the main drawing I have frozen some of these. However, the background mask is stil...- 20 replies
- view ports
- background mask
Multileaders, Annotation, and Background Masks
CyberAngel posted a topic in AutoCAD Bugs, Error Messages & Quirks
I have a survey xrefed into a site plan. In the survey there is a multileader that needs to appear at two different scales, so I made it annotative. The same multileader sits on top of a hatch (which is in the site plan), so I gave it a background mask. At 1"=20', the larger scale, I can adjust...- 1 reply
- background mask
- annotation scale
Background Masking wont delete
clarkey1987 posted a topic in AutoCAD 2D Drafting, Object Properties & Interface
Hi all am new to this site so please bare with me i am currently having a problem which (looks like) i have a background mask that will not delete even tho there isn't any text there. i cant select this or delete it. that's a print screen of one of the areas that's effected if s...
