Showing results for tags 'automation batch process'.
    • automation batch process ×
  1. Could anyone help me with it?? I am trying to install Global Attribute Extractor & Editor (http://www.lee-mac.com/macatt.html) on a colleague's computer which has Windows 10 inside. When I run extractor or editor, Autocad let me to state all the blocks and the files. However, when i press ok b...
  2. We were using this routine to update/redefine blocks inside a drawings in a directory (ei. 200 drawings) without user input upon invoking the "red" command" The routine reads the dd_list.txt created from a batch file. dir /b *.dwg > dd_list.txt then R&W the list with Open, qSave, close comman...
