Showing results for tags 'autolisp code problems'.
How to create a Amnote in AutoCAD Mechanical
muhammad_rp posted a topic in AutoLISP, Visual LISP & DCL
hi guys, my name is ramdan i live in Indonesia, I want to Ask, how to make amnote in AutoCAD Mechanical with Autolisp ? thanks,- 1 reply
- autolisp programs
- autolisp code problems
- (and 3 more)
(defun c:sbb(/a b) ((setq a 10 b 5) (if (> a b) (progn (princ a) (setq a (+ a 5) b (+ b 6)) ((princ a)(princ)) ((princ b)(princ)) ) ) ) )
Error for ObjectID of polyline using vlax-curve-*
HelplessIntern posted a topic in AutoLISP, Visual LISP & DCL
I have just started learning AutoLISP from different posts on the forums and through the reference material from Autodesk but, I am hitting an error in my lisp routine that I don't know how to fix. I am trying to right a while loop that will go through a nested list and use information in the select...- 10 replies
- objectidcollection
