Showing results for tags 'autodesk architecture'.
    • autodesk architecture ×
  1. I have few .arx applications for AutoCAD. In these applications few are menu based and others are command line. Now what I am trying to do is, Load the .arx app, run it and then unload it once the .arx application runs through a LISP command. .arx applications run once the user clicks on the t...
  2. Pyro
    Autodesk Software Marketing
    I have been using autodesk architecture for some years now and recently have been hearing and seeing a lot about revit architecture. what intrigues me is why does autodesk promote revit above autocad or why the shift from cad base to revit? would appreciate some sort of feed, thanks for any clarific...
