Showing results for tags 'autocad mep'.
    • autocad mep ×
Found 12 results
  1. Hi friends, this is my first post here . I am relatively new to Autocad MEP . I recently got a job as Mechanical Engineer in an HVAC design and installation firm in a junior level, and I need to practice before joining. I tried learning the software by my own through youtube and several of my do...
  2. tzframpton
    Pipe and the Display Manager
    Posted this at the Swamp too, hopefully something comes up. I'm having a bit of an issue trying to dig through the Display Manager to get the proper visual outcome for my Plan View mechanical piping. I simply started a QNEW drawing template defaulted from ACAD MEP. Using the MEP Design Displ...
  3. First I'll say that currently this is stemming from an HVAC drafter/ designer that just wants to put out some quality drawings in an efficient amount of time with not a lot of hassle - kind of like in AutoCAD. This is also coming from 20+ years CAD experience here so I am not talking out of my arse....
  4. hello everybody, im making this question because in my company we are thinking about really step forward from regular Autocad to MEP, until now we have been only creating some 3d models of some specific parts of some projects to explain better how the installation should be done. However now, my bos...
  5. Andrew Michaelson
    Rolling a 45 bend in Autocad MEP 2013
    G'day Everyone, I'm trying to roll a 45 degree circular elbow to pick up a 45 degree takeoff from a main vertical duct so as to save on using an extra bend and cannot work out how to do this. I have noticed when you select an elbow in your drawing there are grips which you can select to rotate it....
  6. jojit
    MEP Beginners
    ..How can I put dimension in a 3D drawing specially the height...and regarding the pipe support, I think only a channel hanger is existing in MEP 2011.How about support for the PPR and BS pipe?
  7. Hi all. My company is fairly large for an electrical contractor, and we're all over the board in CAD experience. We have people that started as hand drafters back before computers (and STILL prefer hand Drafting over CAD or 3D CAD or even BIM), and we also have a couple proficient in BIM, and ev...
  8. I am running AutoCAD MEP 2012. Does anyone have a basic routine for a conduit leader?
  9. I guess my question is clear, can I use revit parts made by manufacturers in AutoCAD MEP? example, grilles and diffuses (revit format) supplied by Titus: http://www.titus-hvac.com/software/Revit.asp Thank you very much!
  10. Couldn't find a solution to this anywhere so hoping you guys can help... We are working with a client who is drawing there files in Autocad MEP. The issue is when XREF these drawing into ours they either show up like line diagrams (see image below) or not at all. We solved the not at all portio...
  11. How do i run Vanilla AutoCAD from AutoCAD MEP 2011? The "Right click on the AutoCAD MEP shortcut icon on your desktop and look for the 'Open File Location" does not work Thanks
  12. Siberian
    To pass one pipe with another
    Haven't used MEP since the 09 version, looking at the 2011 now. What I want to do is simply to pass a pipe with another pipe so that the bottom of one passes the top of the other. The closest I get is aligning the center of one with the bottom of the other. Anyone?
