Showing results for tags 'autocad map'.
LISP: Increase consecutive number & Object data to block attribute
BRIAM RAMON posted a topic in AutoLISP, Visual LISP & DCL
I would like to merge the lisps I show at the end into one, where the process is first ADDID.lsp and then OD2ATT.lsp If it were possible with your help to add a new functionality to addid.lsp and that is that when you copy the block name in the TIPO_SENAL field of the Object Data You c...- 1 reply
- lisp
- autocad civil 3d
Hello, As part of a project I must assign an object data table to all elements of the drawing according to their layer. I am looking for an automated solution to assign the Objects Data tables to the elements of the drawing other than by selecting the different layers one by one. Knowin...
- 3 replies
- object data
- vba
Hi guys, Bit of a strange request. I'm looking for something that will shift a selection of polygon vertices by a random amount for each vertex. In a perfect world I'd love to set a tolerance of say 5cm and have the vertices move in any x,y direction by random amounts up to 5cm. Any idea...
Hello everyone. I'm new to this forum so please forgive me if I'm doing something wrong. I would like to populate a SDF feature data table in AutoCAD Map 3D with a autolisp routine. I've been searching the internet for days and could not find any clues so I assume it's not possible to do that....
- data tables
- autocad map
I need autocad map 2004-2007 (one of them). I tried to find with Google. But didn't find any good result. Can any one tell me where i can get them? Thank you.
