Showing results for tags 'autocad lt'.
detached XREF layers keep crashing drawing
DIFOULD posted a topic in AutoCAD Bugs, Error Messages & Quirks
HI there, Am working on an AutoCAD LT drawing with several XREFs. I have been hatching some small areas and, last click of the day (isn't is always) one of the hatched areas appeared to leave the defined boundary and created a new hatch ALL OVER the main drawing, referncing multiple area...- 1 reply
- autocad lt
- xref
We would like to buy two new licenses of AutoCAD LT. In Autodesk website, they are advertising the Pay-as-you-go license which seems to be a pretty good deal ($360 per year or $45 per month). What do you think about purchasing this instead of perpetual license? what are pros and cons? Do you recomme...
- 13 replies
- autocad lt
- desktop subscription
For some reason parts of my PDF underlay, certain walls and such on a building I'n working on, won't show up. The project is not worth the time to redraw and should be something simple for me to slap over the underlay. I'm not sure if I'm doing something wrong, I've tried my regular troubleshooting...
- 1 reply
- autocad lt
I'm using the Japanese version of AutoCAD LT 2008 and when I use Dtext only Japanese characters display. If I open a new file I can type in English but not in the file my workmate gave me. I paste in English text he wrote (e.g. R0 S0 T0) but I can't paste text from anywhere else. If I type in Englis...
- 8 replies
- character display
- autocad lt
Objects missing in paper space tabs
BudRPerry posted a topic in AutoCAD Bugs, Error Messages & Quirks
We have recently upgraded to 2014. Some of our plans created in 2011, when opened in 2014 have most of the objects missing in the paperspace tabs. This includes lines, polylines, blocks, ole objects, jpgs, and plain text. These are not xref'd items. A few members of our staff have LT 2014 and have o...- 14 replies
- missing objects
- autocad lt
Hi, For my work i am now responsible for the drawings. Six months ago, i never had worked in a drawing programm. Now i have followed Autocad-lessons for four days. It is less, but for the most things i can help myself. Ik work with Autocad LT 2012 For the drawings that i have to make for...
- 14 replies
- screwthreat
- screw
inserting a JPEG into my autoCAD LT drawing, and PDF it
matt lyons posted a topic in AutoCAD Drawing Management & Output
Hi, I am using AutoCAD LT 2009, and am having some problems. I want to have some jpeg images on my cad drawing, so i just insert the image, which is fine. I can print this fine, and allis good. however,when i go to PDF the drawings, using a standard downloadable DWG - PDF convertor, the jpegs...- 5 replies
- insert jpeg
- autocad lt
I work at a sheet metal fabricating shop and we get files from clients using Inventor. I have to take their dwg's program them for our laser machine or waterjet, or plasma cutter. I am using Autocad LT 2011. we use Fabriwin to actually program the machines. Ok back to what i'm looking for. I need to...
I am currently using AutoCAD LT, and I have been racking my brain trying to figure out how to create a table using a simple script. Is this even possible with LT, and if so, does anyone have any helpful advice?
- 5 replies
- script
- create table
I'm about to buy a new AutoCad version. I only do 2D drawing and LT seems best for me. However, I must be able to export to eps without fuss like I can do in my current AutoCad. Feedback is welcome before I part with my cash.
- 4 replies
- eps
- autocad lt
Plot multiple layers via script
pharrold posted a topic in The CUI, Hatches, Linetypes, Scripts & Macros
Hi, I have a script that will plot layers automatically without me going into layer manager and changing them and then clicking plot. The drawings i will be working with are electrical, they have many layers in one drawing. the layers are not sequentially numbered so makes the script harder...
