Showing results for tags 'autocad lisp'.
Hello, can anyone help me please with this topic? I have 9 layouts. I've inserted the same block to each layout. I want to change some attributes (the title of the drawing inside block) for each layout out of those 9. The Layout name is variable according to the number of project wh...
- 14 replies
- lisp
- autocad lisp
Hi everyone, we have already placed a block object in multiple locations. Now we need the same block in a converter rectangle array format. Is there any idea or Lisp program available?ilable
Hello, I need help regarding to change the linetype scale of every line on a certain layer based on its individual length. Thank you.
how to do the automatically offset in between two lines offset centerline for all
amarendra posted a topic in AutoLISP, Visual LISP & DCL
Hello Dear Friends, how to do the automatically offset in between two lines offset centerline for all. kindly find the attached for sample image with drawing. if anyone knows lisp please help me. I am using AutoCAD 2017 Thanks Amarendra HVAC sample Off... -
Dear All, I am completely new to autocad programming and want to take professional help or advice for getting the following task completed : 1. Import dxf file 2. Assign measurement data to premitives for tolerance. 3. Import point cloud. 4. Orient point cloud on cad entities. 5. Verify...
Hi everybody I have few question about AutoLISP. before that, I would like to write few lines about my AutoCAD-related skills. I can use 2D CAD almost perfectly and I know some basic features of 3D. I know how to use excel or simply note pad to create lines of texts containing CAD command and...
