I use Dynamic Block and insert attribute field for value - placeholder - name. here is a print screen - http://joxi.ru/l2ZYpRXU88VExm
If i attache the file from a reference in another file, this bloc shows the block name and file name in attribute value.
view here - http://joxi.ru/zANBvYdfllwB...
Hi,
I have a 3d structure, and I want to know if there is a way to know the mass?
What I do at the moment is, I find the Volume 'OBJECT' divide it by 10^9 and in the end times the density of the material.
If its possible I want to learn how to do it with FORMULA in a TEXT FIELD.
Thank you
