Showing results for tags 'autocad electrical'.
    • autocad electrical ×
Found 7 results
  1. Hi all, I am fairly new to AutoCAD Electrical but I have created some symbols using the symbol builder. The problem I am having is when I want to edit those symbols I created. After making my changes I am prompted if I want to overwrite the existing files, and I select yes. However, when I t...
  2. I am creating an excel worksheet from autolisp to populate with all of my fuse information from autocad electrical 2011. Everything works fine except that I cannot figure out how to change the width of the columns in the excel spreadsheet from autolisp. Any assistance would be greatly appreciated....
  3. I am working on a project where it involves relocating of some optional stand-by loads to the emergency side. On the demolition electrical oneline drawings when the load is being demoed it is shown as dashed lines with mark up as demolished. How is a load which is not being demoed but re-l...
  4. cadcamcaeworks
    Book on AutoCAD Electrical
    After going through the titles and manuals related to AutoCAD Electrical. I found that there is a lot lag between practical use of AutoCAD Electrical and its manuals available. So, I came up with a title AutoCAD Electrical 2015 Black Book. Please check this book and provide your feed back. I will tr...
  5. I have autocad 2012 installed on my system, now i want to install autocad electrical. What would I have to do? I think autocad electrical is not a separate programe, it is just a plugin. but I am not sure. Is it really so? If so what would I have to do to install that plugin?
  6. I am a electrical engineer and want to be expart in autocad electrical.please give me some tutorial .thanks.
  7. DesireeK
    AutoCAD Electrical Set-up
    I am new to this, trying this out to see if anyone can help me. My company is on board with switching to AutoCAD Electrical 2011. However, my boss now wants a list of what needs to be done to start using the product. What needs to be set up or learned? I have played around with the tria...
